Impala MAF difference
Old Feb 11, 2005 | 02:42 PM
blueta's Avatar
I just bought an lt1 from a 94 impala. It's got most of the parts except it's missing the mas air meter. Is there a difference (besides size) of the lt1 one and the impala one?
Old Feb 11, 2005 | 02:44 PM
redcamaroz28's Avatar
Re: Impala MAF difference
I believe the Impala is a 3" apposed to the f-body 3.5" MAF
Old Feb 11, 2005 | 08:32 PM
blueta's Avatar
Do they use the same style connector? Can either be used?
Old Feb 11, 2005 | 11:09 PM
96capricemgr's Avatar
Same wiring just make sure the pcm is flashed for the appropriate sensor(whatever you use) because they do read differently.
Old Feb 11, 2005 | 11:52 PM
The PCM program is calibrated for the particular meter (as 96capricemgr was saying). So even if you could plug it in, it would not read the same to the PCM as the stock unit. IMO, stick with the f-body MAF.
Old Apr 17, 2005 | 11:45 PM
BlueCamaroZ28's Avatar
I bought Impala MAF to replace my defective F-body MAF. Would I be running rich or what? My engine is 385 with cc 306 and 30# SVO's. Was tuned by Pcmforless for ported MAF.
Old Apr 18, 2005 | 12:15 AM
Ram Air 9C1's Avatar
The tune will be way rich. The pcm will dump too much fuel because it thinks that there is a lot more air coming through than there actually is. Also, Impala MAF maxes out at around 330 gm/sec which is approximately 320 rwhp.
Old Apr 18, 2005 | 08:44 AM
What's a quick fix without replacing the MAF. I know tuning will do with rich condition but what about the restriction. Will descreening and/or porting the MAF help push more air through.
The Ace Delco impala MAF cost me $93.Where can I get an F-body MAF for around such a price.
Old Apr 18, 2005 | 05:52 PM
The rich condition can be easily fixed with programming.
A ported MAF will push more air but it's easy to screw up a good tune this way. It still won't support over 350 rwhp.
Javi Fierros
Wheels and Tires
Jun 11, 2015 07:41 AM
jj_burchiel
Mar 5, 2015 07:05 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
