I'm guessing opti
Old Jul 15, 2008 | 01:43 PM
lightskindwonder's Avatar
I'm guessing opti
I've replaced 02's, MAP, changed TPS, EGR, new plugs & wires, ignition coil, checked my fuel pressure (seems fine 35-42psi at all times), replaced fuel filter....yet my car still seems to bog or hesitate when i try to accelerate really quickly from a dead stop out of 1st gear. this continues till about 2k rpm or so, then picks up and runs normal throughout the rest of the power range. I've checked for leaks throughout the intake system including in the back of the manifold and don't seem to have any. my icm & coil have been spaced away from the head, so i don't think it could be a heat soak issue, although the bog does seem to be more pronounced after normal operating temp is reached. water pump is new so no leaks on the opti, however, i'm not sure if the opti has ever been replaced since before I bought the car. what do you all think...change icm first, then opti? is there a way to test either one?
Old Jul 15, 2008 | 02:33 PM
IPrice's Avatar
Go try to tutorial at Shoebox's website.
http://shbox.com/1/4th_gen_tech2.html#opti_test
A schematic is here:
http://shbox.com/1/95_ign_system_schematic.jpg
You'll nail it down there.
Good luck,
Ivan
Xiantyl
Jul 21, 2015 05:42 AM
Dark Zeiro
Jul 19, 2015 08:25 AM
Latronaxe
Jul 17, 2015 11:55 AM
RUNMYTA
Jul 15, 2015 07:50 PM
asilomar244
Jul 12, 2015 05:53 AM
