I'm gonna break this thing....valve lash
Old Dec 18, 2003 | 05:24 PM
S.J.S.'s Avatar
Okay I'm frustrated ta shieet. I'm trying to djust my valves with the car running. Everyone says to back off the nut until you hear the clacking...then tighten til it stops. i can hardly tell the diff. They also say the nut shjould spin freely and when it stops...go a quarter turn after that. mine don't spin freely. i can hear 8 rockers. Anyone got to this point and just wanna throw a wrench in it???
Old Dec 18, 2003 | 05:31 PM
dobe's Avatar
never tried to adjust the valves while motor was running
but i havnt had any problems that i know of doing it not running...
Old Dec 19, 2003 | 05:10 AM
2ZPOINT's Avatar
Not the nut...the pushrod should spin freely
Old Dec 19, 2003 | 06:47 AM
94_Z28_guy's Avatar
I thought the same thing. I thought it was a PITA.
The clack is pretty loud. Are others clacking also so its hard to distinguish? If they are you might want to slowly tighten them all down so there is no noise, then start loosening one at a time until it clacks, then 1/4 - 1/2 past that.
I couldn't do it with the spinning pushrod way, the rockers were always loose when I ran the car.
Old Dec 19, 2003 | 07:09 AM
Newbie97's Avatar
Those are the instructions right there. You should hear the ticking from the one you are loosen. You should also get alot of oil splash from the one you are loosen . If not you havent loosen it enough.
Old Dec 19, 2003 | 08:19 AM
ComputerNerd's Avatar
I plan to do mine this weekend. Here is a website I found searching the board. Steps 22-25 gives you two methods to do the adjustment.
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Bxlt1
Sep 29, 2015 03:18 PM
Aug 17, 2015 09:50 AM
