I'm buying a Dyno!
Old Dec 18, 2003 | 12:37 PM
IslandZ's Avatar
I'm buying a Dyno!
LOL, well I'm doing the research to maybe buy one.
What is your experience with different dyno's and which do you think is the best?
I'm looking into maybe getting the dynojet unit, but everything is still up in the air. We do not have a dyno place here on the island and it is always good to be the first!
The board can be sure that I will document EVERY mod I make with before and after dyno runs after I get a dyno!
Please tell me your experience and how much you paid for a run.
Thanks!
Old Dec 18, 2003 | 12:40 PM
FyreLance's Avatar
That would be awesome
Old Dec 18, 2003 | 12:42 PM
LWillmann's Avatar
My first trip to the dyno cost me $75 for three pulls, but he gave me 6.
My 2nd trip was on a club dyno day and it was $35 for three pulls.
If you purchase your own dyno, I'd recommend a dynojet, and do it in-ground if at all possible! You don't want yourself or anyone else to fall off of it.
Old Dec 18, 2003 | 12:52 PM
germ79's Avatar
Smile
I had the same thought as you. There wasn't one anywhere near here and I started looking into it too. The only problem for me is that you NEED to have a performance shop as well as a dyno. You need to be able to dyno the cars and then sell/install what they need to make more power so they will dyno again! If you have a dyno only, you will most-likely go out of business after most people try it once. Maybe you are a mechanic, so that would be perfect, but I am not.
I was looking into this a couple months ago and just last week I found out someone opened a dyno only 45 minutes away! There goes that idea!
Hope this helps!
Jeremy
Old Dec 18, 2003 | 01:29 PM
Fastbird93's Avatar
Man, those things are farking expensive. The guy who I use got his used for something like 20G's. Some inordinate amount of money.
He only charges $50 for 3 pulls with wide band though!
Old Dec 18, 2003 | 02:01 PM
96 WS6's Avatar
60 bucks for 3 pulls here.
Old Dec 18, 2003 | 02:45 PM
Tommy'Z 6speed's Avatar
I saw a new dyno concept a month or so ago.
You jack up the car and remove the drive wheels. Then two "dyno cells" are slid into place (mounted on casters) and bolted to the drive wheel flanges. These "cells" are about 3 feet cubed.
The car is then lowered back down and the dyno run is done.
They are relatively compact and supposedly more accurate than a roller setup. Much quieter too.
I don't know about the cost, but the concept is interesting.
Old Dec 18, 2003 | 03:32 PM
Antz97ZNJ's Avatar
crazy idea,but hey if that whats gonna float your boat go ahead...I think having a performance shop around it would be much more profitable
Old Dec 18, 2003 | 03:40 PM
scoobysnax83's Avatar
That sounds "farking" ridiculous! They must create some kind of back pressure or you will have problems. I'd have to see it to believe it, but even then, sounds fishy.... Imagine jacking up your car and then putting it in gear and going at it. Won't be long till something goes flying off.....
Old Dec 18, 2003 | 03:54 PM
Chevycobb's Avatar
I have seen this too! I saw someone on tv using them...some speed channel show. They looked to be very easy to use and compact
Old Dec 18, 2003 | 04:01 PM
red's Avatar
red
I looked at these at the PRI show last month. They get around $40K for each unit
Your better off going with a floor mounted Dynojet and save money.
Old Dec 18, 2003 | 04:36 PM
Chris 96 WS6's Avatar
$20,000 is really low, must have been used. I was doing a business plan for opening a full service perf shop a while back....a fully optioned Dynojet with above ground lift kit and Wide band 02 logging was over $40,000 US.
In-ground will save you $8,000 but you have to construct a pit to install it in, so either way there is additional work or money involved.
Good luck!
P.S. I would recommend looking into Superflo brand dynos...They have a model that does both eddy current and inertia style testing (Combines best features of Mustang and Dynojet brands) and is very comparable in terms of output to the Dynojet. The eddy current capability can really make you some money, because the dyno can put a real-life road load on the car, can be very good for diagnostic work and tuning.
Old Dec 18, 2003 | 05:16 PM
amean94ta's Avatar
$100,000 for that one its made in sweden.
but imho the land and sea is the best thats what we are buying check them out
Old Dec 18, 2003 | 05:17 PM
amean94ta's Avatar
you were there to what company were you with i was krs machining in erie
Old Dec 18, 2003 | 07:06 PM
Brent94Z's Avatar
Super Moderator
I looked into buying a dyno for my new garage. A new one was around $50k and I found a used one for around $25k. There is NO dyno anywhere around here and I'm sure I could make the monthly payment just off a weekend worth of runs. But, I live in a residential neighborhood so I would have some "details" to work out
Good luck with the venture! I've looked into it *briefly* and I'd bet you could make a go of it. You'd probably gain a lot of new "buds" too. LOL!
