Ignition Switch or the key lock and tumble??
Old Jan 10, 2005 | 12:20 PM
BigTedz28's Avatar
Ive been having a slight problem the last few days, and it seems to me like the ignition doesnt want to stay in the on, position for my fuel pump to turn on, but soon as i turn it a lil bit more, all my lights starts to come on my dash board and all, as soon as i start my car, if i let the key go, it goes off, if i hold the key a bit, it will stay on, but only with my help.....?? is this the iginition switch .......or my lock and turn ign, hole......???
Old Jan 10, 2005 | 12:23 PM
med_reject's Avatar
Re: Ignition Switch or the key lock and tumble??
when that happened to me, it was the ignition switch. I didnt have issues with my lights, but when i let the key go back, the car would shut off. If i gave it some gas and fiddled with the key, i could get it to run eventually.
I replaced the key lock and cylinder and that did nothing.
Old Jan 10, 2005 | 12:26 PM
LT4383's Avatar
Sounds like the ignition switch to me. You may be able to get a way with adjusting it. Very easy to replace though.
Old Jan 10, 2005 | 03:11 PM
BigTedz28's Avatar
???????very easy to do huh?????????????
hmm well can y0ou give me a website so i can follow it for steps ....? thanx
Old Jan 10, 2005 | 03:44 PM
Sure, mine. I would not categorize it as very easy, but it's not very hard.
You might want to try moving the tumbler around while you have the rod disconnected from the switch, just to try and make sure you don't have an issue with that part of it.
Old Jan 10, 2005 | 03:45 PM
'94 Bad A Z28's Avatar
Deffinately the ignition switch.
Heathen1
Jan 2, 2016 04:27 PM
robcarnut
Mar 20, 2015 03:40 PM
Dzmaro
Jan 25, 2015 10:39 AM
