ignition stuck question
Old Jun 22, 2004 | 05:43 PM
airborneluva's Avatar
Question ignition stuck question
today I parked my car and couldnt turn it off.. The ignition seemed to be stuck. Any ideas what i should look for? why its doing it? Car is a 96 trans am with 70k
thanks again as always
Old Jun 22, 2004 | 05:46 PM
Explain more. Stuck how? Some help, if your situation is the same.
Old Jun 22, 2004 | 08:41 PM
the situations seems similar. the car is a manual, the key was in the on position but stuck so that I couldnt turn the key backwards to take it out. the key lock button didnt seem stuck, i depressed it like usual but the entire key knotch wouldnt turn back, eventually after fighting with it it did however.
Old Jun 22, 2004 | 10:29 PM
Similar, maybe, but not the same as the help I posted since it is for an automatic (that's why you should post more pertinent info when you ask for help).
Could be your key cylinder or mechanism in the steering column is messing up or your ignition switch (which is down on the lower part of the column) is worn out and hanging up.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
tds1213
Nov 27, 2014 12:55 PM
lbrowne
Nov 13, 2011 04:25 PM
Brent94Z
Mar 21, 2002 04:44 PM
