ignition module problem
Old Jun 3, 2005 | 11:00 PM
Whitewolf's Avatar
I had a right bank lean code..and the car was cutting out at high rpms.. it was on and off not all the time..chased the problem for months..well come to find out changed the ignition module and the car pulls and runs like a new car. I will have some new times posted soon..now some NX passes!!!!!!!!
just for peoples reference.
Brad
Old Jun 3, 2005 | 11:24 PM
screamin94Z's Avatar
Re: ignition module problem
thats weird that it would show up as a bank 1 code but good to hear you got it worked out!
Old Jun 4, 2005 | 06:54 AM
Whitewolf's Avatar
Well it was very hard to find..because it wasn't consistent..sometimes it would miss..other times it would run great..sometimes it would just die..other times it would run ok..then I went out and had it running..pecked on it with my knuckle..it died ...thought ok..tried to start it..it cranked and cranked ..nothing..tapped on it some more..next time started right up..after the swap I have had no problems and the car will spin all through second now..niceeeeeeeeeeeeeeeeeeeee!
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
dluna333
15
Mar 13, 2015 12:30 PM
Ari G
Dec 11, 2014 03:21 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
