Broke a header bolt...
Old May 10, 2005 | 04:51 PM
narlydude's Avatar
Ok so when i was installing my Jet-hot LT's i ran into a minor set back. I broke the last header bolt off. I have all the tools to get it out. Should i pull the whole motor and get it? or can i just pull the head and get it from there? if i pull the head will i need a new gasket? if you could steer me in the right direction i would greatly like that. thanks
Old May 10, 2005 | 05:05 PM
Got-LT1's Avatar
Re: Broke a header bolt...
Same thing happened to me. I pulled the head and yes you need a new head gasket.
Old May 10, 2005 | 05:18 PM
narlydude's Avatar
ok do you know how much that would cost me
Old May 10, 2005 | 05:52 PM
Spinner's Avatar
30-40 for a gasket and 40 for a new set of bolts.
Old May 10, 2005 | 07:36 PM
Hyperspeed97z28's Avatar
what bolt did you break ?
last one on the drivers side ??
how did it break ?
Old May 10, 2005 | 08:30 PM
)2overt SS's Avatar
Could you possibly take pictures of it? There is nothing sticking out of the bolt hole? (i.e. you can't get vicegrips or anything on there to back it out?)
I stripped the bolt hole on my last one when I did my Jet-Hots... I had to drill the hole, tap it and put in a helicoil, and then bolt it back up... worked like a charm.
Old May 14, 2005 | 01:29 PM
narlydude's Avatar
how did it break ?
second to last bolt on the driver side
Old May 14, 2005 | 01:31 PM
narlydude's Avatar
the bolt is broken in the head and nothing is sticking out and its not flush its actually in. I am renting a 90 degree drill tomorrow and im gonna try to twist it out with that lil tool thing. lol i got get the name, reversed thread
Old Jun 3, 2005 | 11:45 PM
zlightning's Avatar
Ever get this solved? I had this happen to me and don't know what to do.
Old Jun 4, 2005 | 01:37 AM
keng's Avatar
Did you fix it?
Old Jun 4, 2005 | 07:02 AM
Bow94z's Avatar
pull the head, and send it off to a machine shop
sscott
Jan 17, 2015 04:30 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
