ignition maybe?
Old Nov 9, 2005 | 06:09 AM
cb94ta's Avatar
ignition maybe?
Here's my problem here lately my 94 ta when you turn the key to start it the dash lights up but it doesn't even try to turn oyver, you can sometimes just hold the ignition on and it will turn over but usually you have to turn i off, turn it on and hold it a minute and go throught that a few times then bam it just starts right up, what the hell could cause that?
Old Nov 9, 2005 | 06:48 AM
SS RRR's Avatar
Re: ignition maybe?
It could be the contact on the ignition switch is worn or the wire (smaller and possibly purple) on your starter is loose.
If the wire is not loose then take that wire off the starter, prod it with a volt meter and check the reading. I think the reading should be 12v.
Old Nov 9, 2005 | 10:01 AM
cb94ta's Avatar
Re: ignition maybe?
thanks I'm gonna check it before I had to work
Old Nov 10, 2005 | 02:02 AM
SS RRR's Avatar
Re: ignition maybe?
Forgot to mention when prodding the wire you must have someone turn the key to the start position before any voltage can be read.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Aaront810
Sep 11, 2015 11:24 AM
