Ignition Issue: Key Won't Hold
While trying to start my car the other day, I got it started and then it died.
I then noticed that when I went to put the key in the forward position to activate the fuel pump and accessories, it would not hold. In turn trying to start the car it will start, but once the key returns to the run position it just moves back.
Would this be a ignition actuator/rod issue?
Thanks for the help in advance. I have never played around with ignitions or cylinder locks before.
Car is a 1994 Camaro Z28 Convertible 4 Speed Automatic.
Re: Ignition Issue: Key Won't Hold
Sounds like you need to look at the switch (on the lower part of the column) and maybe make an adjustment. Either that or your switch is going out.
You should be able to find enough info in my guide for replacing the switch to help with your problem.
Thanks shoebox,
I read your article, but by adjustment what do you mean?
I also noticed that you did talk about the gauge cluster failing and I have been noticing my speedometer jumping around once and a while when I drive over 60 mph. It will flutter by 10 mph, but then once I go slower or have a smooth road it seems to operate normal.
Thanks shoebox,
