Ignition Control Module different for different years?
Old Nov 11, 2006 | 05:02 AM
Hood_Lum's Avatar
Specifically are the 94 different from the 96?
They look the same.
Old Nov 11, 2006 | 06:04 AM
Guest47904's Avatar
Guest
They actually are different part numbers. The 94 ICM was fed 12 volts through the coil. The 96 ICM gets it's 12 volts externally through a harness change. As far as interchangability, it depends on pin outs. According to the schematic, the coil pin outs are reversed as far as A terminal and B terminal from 94 to 96. They do not appear to be interchangable. BTW the coils also have different part numbers.
Old Nov 11, 2006 | 02:11 PM
Hood_Lum's Avatar
Is there a way to measure the ICM with a multimeter to test if it's still good?
Old Nov 12, 2006 | 07:33 AM
Guest47904's Avatar
Guest
No, the only thing you can do is check the IC signal going to it from the PCM and confirm the coil is good. Obviously if both of those are good and you still have no spark, the ICM is bad.
squarehead
Jan 15, 2015 07:02 PM
Ari G
Dec 11, 2014 03:21 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
