94/95 computer into 93?
Old Nov 11, 2006 | 11:07 PM
Blown93Z28's Avatar
Is this possible? How diffcult? Im asking becuase id like to have a flashable computer to use say lt1 edit. would it be worth the switch? also i beleive i have a quad driver failure so its my understand i may need a new computer anyways? Thanks
Sean
Old Nov 11, 2006 | 11:18 PM
lethal93ta's Avatar
as far as swaping out ECMs its to much work, you have to get a new harness for everything, 94 and newer is mass air flow and SFI everything is diffrent and nothing matches up inside or out, you would need to rewire everything, thats why I went with a DFI system so I dont have to deal with burning chips but at a huge cost,
the QDM code check your fuses a lot of times the air pump locks up and pops a fuse. that will set a QDM code.
Old Nov 12, 2006 | 07:43 AM
A QDM code does not mean you need a new computer. It's often just the AIR pump, as already suggested.
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
fireside286
Sep 15, 2015 10:11 PM
350350
14
Aug 11, 2015 12:03 PM
