Ignition Coil Selection
Brands (available at my local parts houses):
I have read many hypothetical reasons why the cheap coils aren't worth dealing with, but very little technical data or numbers that indicate their specifications. I will be testing my coil (1994 style) tonight and should it fail, will be replacing it with one of the above. I will opt for the one that offers best performance with a stock ignition/engine. I would like to make that decision based on performance figures instead of assuming that more expensive means better (often times correct).
If anyone has links to technical data from the manufacturers or results from individual testing for any of these coils, please let me know! TIA
- Master Pro (MPI) - $14.99
- Wells - $14.99
- Borg Warner - $40.99
- AC Delco - $48.99
- Accel - $49.99
- Hypertech - $69.99
A new coil isn't going to add any extra horsepower so it is hard to compare them in terms of performance. I would venture to guess though that the internals of those cheaper coils have cut corners to keep the cost at where they are at which may make long term durability an issue.
I have seen Shoebox post that 96-97 coils are "pretty good as far as spark output" but it seemed like that judgment excluded 93-95. What is the difference besides the connector style?
I can't remember where I heard this, but I have heard that certain aftermarket coils actually produce higher voltage and while that doesn't result in any difference in power, it increases potential to cause a short in other stock secondary ignition components that weren't designed to handle that much voltage. Maybe I'm just off my rocker
Let me know if there is any truth to that rumor.Thanks!
I've had no long term durability issues with any of the cheap aftermarket ignition parts on many cars over the years. Specifically I've used lots of stuff from Wells. Not sure about MPI.
I'd venture that most of the price difference comes from cheaper labor.
My MSD coil was DOA. I was told that all the aftermarket coils are made by the same company or at least made the same way, so there's no real upgrade. Go with AC Delco or the cheapest one you can find that isn't refurbished.
