Which Ignition Coil Accel or MSD?
Old Mar 2, 2004 | 06:38 PM
LeeS's Avatar
Question Which Ignition Coil Accel or MSD?
I have a 1997 Z28 with 79,000 miles on it. I need a coil.
The Accel Coil has a primary resistance of 0.2 Ohms and Secondary resistance of 6.7k Ohms. Output 48,000 Volts. Part#140024. Price 41.95
MSD has a primary resistance of 0.5 Ohms and Secondary resistance of 6.5k Ohms. Output 40,000 Volts. Part#8231. Price $39.99
What do you think? Both Coils will bolt up to stock position.
Thanks Lee!
Old Mar 3, 2004 | 12:36 AM
stillalarm's Avatar
I had a MSD coil and it only lasted 13 months!! IMHO, it's a piece of junk. I'm back to using the stock coil.
Old Mar 3, 2004 | 12:38 AM
phrozen's Avatar
I know a couple people running the MSD 6a in their 76 gt400 firbird and 67 falcon. they really like 'em.
opps, I just noticed you said coil. I'm stupid yes I am.
Old Mar 3, 2004 | 07:31 AM
Why do you need a coil? Have you diagnosed that yours is bad? The 96-97 factory coils are good ones. I doubt you will see any benefit from buying an aftermarket coil.
Old Mar 3, 2004 | 07:54 AM
Jay-Roll's Avatar
You won't see any difference performance wise going with an aftermarket coil. So if that's your angle and you know for a fact that you really do need one, just get a stock replacement. I haven't heard anything about the accel coil, but I've heard the MSD Blaster coil is pretty good. Until the above post that is.
Old Mar 3, 2004 | 09:05 AM
Don 97 SS's Avatar
As mentioned above the only difference you will notice among the MSD, Accel and the oem coils is the price.
Old Mar 3, 2004 | 12:37 PM
LeeS's Avatar
Hi Guys!
Thanks for the information.
Yes Shoebox mine is bad terminals are corroded (hope I spelled it right). and think it maybe arching a little too on the side.
Thanks for taking the time to give me some info. I really appreciate it.
Lee!
Old Mar 3, 2004 | 12:39 PM
Valkyn71's Avatar
will a 96-97 coil work in 93-95s?
im gettin a new coil so might as well get one if its better.
Old Mar 3, 2004 | 12:44 PM
LeeS's Avatar
No Valkyn71, The 96-97 LT1's coil wont fit in the 93-95 modles to the best of my knowledge.
although I could be wrong. The reason 96-97 has a single connector coil while the 93-95 has Dual connector.
Have a goodone Lee.
Don 97 SS's Avatar
The wiring harness is different, but it could be done. I just don't think it would make a big difference.
Old Mar 3, 2004 | 01:21 PM
CamaroBoy96Z28's Avatar
Have a goodone Lee.
I believe thats the other way around. 93-95 are single and 96-97 are dual connector. Plus the stock coil is a damn good coil, the aftermarket ones dont provide any benefit from what I've read, plus I cant really see why they would anyway.
Old Mar 3, 2004 | 01:22 PM
Hi Guys!
Lee!
Ok, so if you have to replace it for maintenance reasons, get whatever is cheaper. They will all be comparable.
markzzzz
Aug 17, 2015 11:08 AM
94Z28LS1toLT1
May 27, 2015 10:44 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
Cam28_boy
Aug 6, 2002 08:40 AM
