Which Ignition box, best for nitrous???
Old Mar 5, 2004 | 01:59 PM
Muskys SS's Avatar
I want to buy an ignition box, and was wondering which one has an adjustable rpm limiter (not pills, like the msd) and a timing retard feature for nitrous applications??? I know there are many that have the variable rpm limiter, but is there one with the timing retard feature?? Also I have a 96 with an OBD1 conversion. Which wire harness will I need. The 94-95 or the 96-97???
Old Mar 5, 2004 | 02:07 PM
Kain's Avatar
Depends on how much bottle you want to run.
100 shot; you don't really need to retard the timing any. Just run some NGK TR6's and you'll be fine. As for a window switch for your kit, the Harlan window switch doesn't have any pills. It's a really nice piece.
150 shot; it depends on how much timing you're running. When you get programming for your hot cam, let them know you'll be running a 150 hit and they'll dial down the timing for you. If not you can always put in a few gallons of 100 unleaded along with the NGK's.
If not, there's always this: http://www.jegs.com/cgi-bin/ncommerc...95&prmenbr=361
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
detroit1994z28
May 14, 2015 12:09 AM
bandit383lt4
Dec 21, 2014 09:12 PM
