If you suspect your IAT.... read inside
Old Sep 24, 2003 | 08:19 AM
  #31
scoobysnax83's Avatar
Originally posted by drewstealth
Scooby is the vortech elbow coated at all? I have the Trickflow and it has ceramic coating. I can't really remember how hot my stock elbow got but i know that while my car is running i can just leave my hand on the trickflow. It doesn't get very hot. I'm not sure about the vortech though. I was sort of thinking the same as you were about robbing me of hp. So i bought a 1le elbow but it wouldn't fit with my slp cai anyways. So i stuck with it.
No the coating must really make a difference because mine gets almost as hot as the intake. You can't even put your hand on it after about 30 minutes of city driving. I may look into getting it coated. If yours isn't getting that hot then I would not worry about it. Thanks for the idea. I may send it off with my headers to get coated.
Old Sep 24, 2003 | 10:33 AM
  #32
drewstealth's Avatar
is it getting hot while the car is on or when it is off?
Old Sep 24, 2003 | 10:54 AM
  #33
David A. Wilks's Avatar
Marvin...
Next time you get locked out, take your towel and open the window by pulling it back. Unscrew your antenna and push it through the opening. you do not have to pull back on the glass much to do this. Use the antenna to push the power door lock button and unlock your doors. I have done this several times without fail.
Old Sep 24, 2003 | 11:39 AM
  #34
MentalCaseOne's Avatar
Good thinking. I just got up and will take her for a spin and read the IAT before work..
Marvin
Note: I am bringing all the keys with me this time...
Old Sep 24, 2003 | 03:07 PM
  #35
BigRich's Avatar
you should memorize that tow truck guy's phone #
Old Sep 25, 2003 | 03:16 AM
  #36
Uddate!! Update!!
Took only one measurement today.. I got lazy sorry.
temp 123* farenheight, IAT resistance 990 Ohms
per Chiltons it should read 954 Ohms or 3.8% off
right where it should be.
I still need a couple of more readings at higher temps..
Marvin
cmsmith
Mar 14, 2015 03:48 PM
carl.froehlich
Mar 13, 2015 12:38 AM
squarehead
Nov 21, 2014 08:02 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
