if you get head/cam package runin 11 seconds, with no power adder, what...
Old Nov 16, 2003 | 12:30 PM
glennxx1's Avatar
is bound to tear up soon? are the stock rods pretty strong in lt1? crank handle a good bit of power? whats' some things that need to definatly be replaced when getting into the 10s? fuel pump, rear end good at high 10 low 11s? ignition? and what actualy determines how many rpms ur engine can turn safely, the strength of your crank, or your rods or...what exactly?
Old Nov 16, 2003 | 12:49 PM
RacinLT1's Avatar
well the stock rear wont last long once you get to the 11's. the fuel system will be taxed if it is stock when you get in the 11's.
quality of the bottom end,cam choice,and balancing affect rpm's.
Old Nov 16, 2003 | 02:07 PM
Wild1's Avatar
Your rear will be the first to go... depending on how hard you are launching and if you're running slicks or not. I've got 4.10s and 285/40R17s. I still don't drop hard on the line but after 3000 RPM in first I'll go 100% WOT. That is on a stick by the way.
Depends on how hard you are on the driveline. But the rear is the weakest link... 10-Bolt.
I can't tell if you are a manual, but your stock clutch might wear a bit too.
Old Nov 16, 2003 | 03:03 PM
atljar's Avatar
I say the rod bolts and main bearings are the weakest internal parts. The rods/crank/pistons should hold some good abuse.
Old Nov 16, 2003 | 08:18 PM
glennxx1's Avatar
aight, thanks alot for the info guys, i am a 6 speed, rear end will go first, kinda just thinkin if i should just buy a bare lt1 block and build it and just drop it in when its complete...but i dunno...if i was goin to change pistons/rods/crank etc...basicly a full rebuuild would i wanna pull or is it hard as hell to pull the engine? i dont like how it sits all under the windshield
Old Nov 16, 2003 | 08:54 PM
Ai's Avatar
Ai
If you're really hooking up, power or not, you're going to start trashing stuff in short order with a manual car. Talk to GreenBeanZ28 if you can, he's down in Easley & has broken just about everything that can be broken thus far
F'n1996Z28SS
Aug 23, 2023 11:19 PM
XtremeLt1
Sep 13, 2002 08:50 PM
LT1runner
33
Jul 24, 2002 01:19 PM
