If you could
Old Apr 8, 2003 | 06:39 AM
darkoverlift's Avatar
Lightbulb If you could
I have the option of either getting a BMR panhard rod or BMR lower control Arms. I occasionally hit the track, but am looking for more street performance. I am looking for something that would help me on the road not just the track. In fact on road performance is drastically more important. I also do not plan to lower the car.
Opinions?
Old Apr 8, 2003 | 07:15 AM
teke184's Avatar
lower control arms....
will help straight line traction and cornering
Old Apr 8, 2003 | 07:18 AM
Derrick Redd's Avatar
I'd go with the LCA's also.
Old Apr 8, 2003 | 07:54 AM
Why LCA's over the other?
Old Apr 8, 2003 | 08:01 AM
teke184's Avatar
they benefit you both in cornering AND straight line, whereas the phb only really helps in hard cornering.
Old Apr 8, 2003 | 08:22 AM
now if I could do sub frames would that be better and why.... I just saw subframes fitthe budget too... Basically I am not going to be able to do anything to the car after this till after summer so I want to make it count...
Old Apr 8, 2003 | 08:54 AM
IDOXLR8's Avatar
I would also recommend going with Lower Control Arms.
Old Apr 8, 2003 | 09:51 AM
teke184's Avatar
sfc are going to tighten the whole car up. allowing the cars suspension to work more efficinently and the way it's supposed to, instead of the body flexing over rough roads the suspension soaks up the irregularities (like it is suposed to do).
the benefit of sfc is stiffer body for better suspension and also it helps eliminate normal body flex that causes sqeaks and rattles in the car.
also realize that i will probably cost $75 -100 to have the sfc welded in.
