if my ac leaked out........
hi guys
i busted one of my ac lines reinsatlling my radiator last night and all the ac leaked out. i could start my car up and have no probs as long as i dont turn on the ac i suppose?? or does it have to be recharged before i start my car? thanks
Re: if my ac leaked out........
Originally posted by slashz28
hi guys
hi guys
Get it charged back up after you fix it, I can't imagine that the closed system would like to be exposed to the elements with it broken and letting air and moisture in.
the compressor turns on even if i dont turn it on?? or youre saying to unplug it just in case someone turns it on by accident? thanks.
If you broke a line you already lost enouf pressure to where you cant engage the compressor. It will spin but its not working the clutch did not engage unless you still have good high/low pressure. You dont need to unhook anything. if you turn ac or the car on nothing will happen.
