If i deleted AIR out of my tune....
Old Oct 11, 2008 | 09:03 PM
glenb1991's Avatar
Do i still need this pump or can it be removed... putting in a turbo so looking for as much room as possible... its the round black pump at the middle of the right side in front of the engine. i saw a tube going to the intake tract... and the other two going to the two pipes i put vacuum plugs over when i got my tuner to delete it... sorry for the crappy pics...
Old Oct 12, 2008 | 02:29 AM
bombebomb's Avatar
You can remove it if you want, its emissions. If you have already removed your converter, then its useless now anyways, make sure to buy block off plugs if useing stock manifolds.
Old Oct 12, 2008 | 09:41 AM
LaredoZ28's Avatar
since its deleted you can remove it. i've taken mine off of both my camaro's with no problem and they had stock tune.
DirtyDaveW
Dec 1, 2016 05:37 PM
HarleyZ28
Oct 5, 2015 06:23 AM
armedtrigger
Feb 24, 2015 08:30 PM
95chwagon
Jan 13, 2015 09:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
