If the front cam bearing is worn = no cam?
Old Feb 24, 2008 | 11:41 PM
  #16
speed_demon24's Avatar
Originally Posted by wrd1972
Great post.
Here was my front cam bearing at ~70K miles, it was gold and scratched all to pieces:
I was was wanting to to do a H&C but did not chance it. I pulled the motor for a full rebuild to the specs in my sig. The stock cammed stock motor ran fine with decent oil pressure. The stock cam had a few scratch marks on the front journal.
Bottom line is its a crap shoot to run a new cam on a worn bearing.
That looks alot better than mine. Mine was copper all around when I did the first cam swap and it's still going strong today. There was no reason for you to rebuild your motor.
Old Feb 25, 2008 | 12:07 AM
  #17
Originally Posted by Jazsun
I've heard that too, and I've heard the opposite. People say you need to rev it to 2k immediately in order to get oil splashed on the new cam.
Both true. Roller cams need no break-in (like flat tapped cams do), but it is good to give it the RPMs, anyway, for good oil splash.
As accessible as the front cam bearing is, a person could replace it, if they wanted to. All cam bearings cannot be replaced with the engine in the car.
Old Feb 25, 2008 | 02:19 AM
  #18
Z-RATED94's Avatar
My front cam bearing had some wear on it. Put the new cam in anyways with no problems. Did put an EWP on though, to take some load off that bearing.
Old Feb 25, 2008 | 08:28 AM
  #19
Z97LT1's Avatar
My front cam bearing looked quite worn also, I slapped a new front bearing in and proceeded with the cam swap. No problems yet.
Old Feb 25, 2008 | 02:17 PM
  #20
Pro_built7's Avatar
so what color is the bearing if it's worn? silver or copper
no im kinda confused weather mine's fine or worn lol
Old Feb 25, 2008 | 04:31 PM
  #21
Jazsun's Avatar
I haven't seen one myself but from reading around..copper. The silver wears down and its copper under I guess...
Old Feb 25, 2008 | 04:51 PM
  #22
Kevin Blown 95 TA's Avatar
The silver top layer is soft and lets particles imbed. The copper layer is a lot tougher and wont imbed particles, but it helps get the heat out of the bearing. Oil pressure is key - As long as you got good oil pressure, you might be OK, but that wear came from metal to metal contact on startup probably, and it will only get worse. You put a new cam in there and maybe scratch it up a little more from the sharp edges, then everything gets a little worse.
Old Feb 25, 2008 | 06:04 PM
  #23
rskrause's Avatar
Moderator
Originally Posted by shoebox
All front cam bearings are going to look worn. It's their nature. Normally, it is not cam bearings that spin, it's rod or mains from lack of oil pressure.
I hate to sound nit-picky, but I think it is an important distinction: bearing failures are due to a lack of oil supply. Pressure is a marker for flow, but not the same thing. I once read that the load on the oil film is on the order of 10,000psi (for the mains). Obviously, 60 or 70psi of oil pressure is not what is keeping the parts for metal to metal contact (even for the cam) but it is the oil "wedge" created by the movement of the journals relative to each other. There are better diagrams, but this should suffice:
Rich
Old Feb 25, 2008 | 07:06 PM
  #24
greenmachinedriver's Avatar
i might be stating this wrong but i think that the cam bearing supply gallery is where the oil pressure is read from because its closest to the pump supply. if the oil pressure drops in this gallery it should effect oil pressure to the rest of the engine. my cam bearing looked similar to the picture above and i went ahed with the swap. the oil pressure droped about 5 psi afterwards. it got worse the more i drove it and within 3000 miles had spun two rods and a main.
Old Feb 25, 2008 | 07:21 PM
  #25
Rich
Ok, maybe I was too general. However, if you are not getting the oil to the bearings, there won't be much chance to have an oil wedge. Pressure may not be the ultimate way to judge what you have, but there aren't too many other indicators available to use.
Oh, yeah...I trashed a rod bearing, but my pressure was still ok. ...lost that darn wedge...
Old Feb 25, 2008 | 07:28 PM
  #26
I would guess pressure at the back by the pump is going to be more than pressure all the way at the front.
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
