idle vacuum for cammed cars
to all the ppl who have big cams what is your vacuum @ idle??
i gauged mine and it's 13. now, i dont know if that makes a difference if it's for a stock motor or a cammed motor...any help?
when i hit the gas, it goes to ~18hg, and then goes down to ~6, and then comes up to ~13.
great, thanks guys!
one more question: after your car's warmed up, when you put it into park and then put it back into drive, does your rpm go down by about 500rpm and then jump back up to what it's supposed to idle at?
for example, when my car's warm, i put into park and then back into drive, and right as it shifts, the rpm goes from the 1000 idle to ~500, and then jumps back up to 1000 idle.
Originally posted by rage366
great, thanks guys!
great, thanks guys!
Originally posted by Fastbird93
So if you have a low vacuum at idle, how do you fix it, provided the obvious (I.E. leaks and blockage) showed no problems? Tuning?
Originally posted by Mikey97Z
Yes, Tuning. By adjusting the spark advance at idle, you can improve the vacuum.
Had another stock bottom end car here a couple weeks ago that had the 230/236 in it. That car seemed to like 31* best. Didn't put the vacuum gauge on it, but map seemed at it's lowest right there.
Both idles were smooth as silk at 1000rpm in park and 950 in gear. TPS and IAC counts were approx .65 and 30.
Hope this helps somewhat.
The larger the cam, the more the overlap. The larger the cam, the more the high rpm efficiency is improved, at the expense of low rpm efficiency. That is why low rpm operation is not as smooth/efficient as oem. Yes, timing will improve a larger than oem overlap cam. Is it a cureall? NO! Don't expect miracles with timing mods when using a cam with more overlap than oem. This is not to state improvements can not be made. BTW Rich, you could have mentioned, (even though it is in your sig.) the stroke of your engine. We both know it makes a diff when stating cam timing specs. Some may not be aware.
F(ast)-body
Feb 26, 2003 09:05 AM
