Idle Surge Problem?
Idle Surge Problem?
1997 Camaro Z28 LT1 A4 112k miles. Stock
I have a weird Idle problem. After I have been driving my car for a while when it warms up, my rpms keep climbing when I'm driving, so even when I have my foot off the peddle I keep going faster. When I come to a stop my idle is around 1500 RPMS, so I have to give it a little gas before it will drop back down to a normal idle. I have recently put new Plugs, wires, O2 sensors, pcv valve, fuel filter, Induction Flush etc... I have no Check Engine light on which leads me to believe it could possibly be a bad throttle cable, or is possibly sticking... however it only does it after I have been driving it for a while. I originally thought it was from my intake manifold leaking but I had that fixed as well.... Could my IAC be bad? I don't have any codes being thrown though.
Any input is appreciated
Tom
Tom
how can I check the IAC out to see if it is bad? Also, I've replaced ever single hose when I did the intake manifold. Why would it only surge when it warms up though... If I had a vacuum leak wouldn't it be surging constantly?
Tom
Tom
I did the Idle Relearn procedure and still have the problem.... I'm now leaning towards a vacuum leak, but don't know where to start looking. Could my throttle cable be sticking? Is there any known problems with the throttle cables on LT1's?
Tom
Tom
Vacuum leaks are tricky to find. I have heard of spraying WD40 all around where the intake seals and along the hoses. If some gets into a leak that you can't see, the idle will go up slightly.
Magenta_Hearts
Mar 5, 2015 07:01 AM
