Idle speed way to high after motor install
I put a new 97 LT1 crate motor in my 93. Had a new chip burned for me by Alvin. But the car still idles at 1500 rpm. I checked my vacuum at idle (so to speak) and it fluctuated from 18-19 lbs. The car has the 94 up intake with no emissions equipment. This motor was complete from chevrolet and I didn't have to change anything except for a couple of the sensors. The car runs great and I have all the bugs worked out except this one. I have already tried replacing the TPS, MAP and IAC with no luck at all on this problem. The idle screw is set back as far as possible without throwing a low TPS voltage code. The only thing I changed on the new motor was the throttle body because I need the transmission cable hookup, and I blocked off the Air and EGR ports with aluminum plates. Is this a vacuum leak possibly? Any help is greatly appreciated.
NOTE : Although this was a new motor it had sat on a shelf for a long time.....
Still running on a 93 computer and sensors no change there from the old motor. I guess it is time to buy a diagnostic cable for it, I have one for obd 2 but not one for this car
. This thing has become mind racking.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
hotrodyou1
Dec 20, 2014 10:05 PM
slothgrant
Aug 22, 2002 03:01 PM
