Idle drop...
Old Mar 9, 2003 | 01:50 PM
vodoo-chile's Avatar
Question Idle drop...
When I change my car from Park to Drive or Reverse, the idel drops from 900 rpm to 450 rpm for about 2 seconds and then returns to normal. It also does this when I come to a stop light. What is causing this and how can I fix it? Thanks,
Kyle
Old Mar 9, 2003 | 08:42 PM
Any ideas what-so-ever? Thanks,
Kyle
Old Mar 9, 2003 | 08:57 PM
kick Z tail out's Avatar
Exclamation
Mine was doing that too.. But it was because my PCM was a POS. lol
It was also not wanting to run on it's own when I fired it up.. I'd have to pedal it and get driving while keeping the revs up by myself. At a light, I'd have to go to neutral and keep the rpm up.
And I was having charging problems too.
Old Mar 9, 2003 | 10:08 PM
Mine drives fine, although I haven't gotten on it too much yet. I want to make sure everything is working fine before I start running it WOT. It only seems to do this when I come to a stop or am changing gears from Park to Drive or Reverse.
Kyle
Old Mar 9, 2003 | 10:17 PM
scott95ta's Avatar
Have you had any programming done to the car?
Old Mar 9, 2003 | 11:01 PM
Yes, by Bryan at PCMforless. I don't have any way of scanning what's going on though.
Kyle
Old Mar 9, 2003 | 11:02 PM
Dave19yz28's Avatar
Check your IAC...also, if you've been tinkering with the intake elbow, make sure the bellows is still stuck into the bottom of the elbow.
Old Mar 10, 2003 | 10:06 AM
How do you check the IAC. I know it is on the TB but don't know exactly where. Also, how do you verify it is working. If it needs cleaning, how? Thanks,
Kyle
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
