Idiots guide to belt and spark plugs
Old May 30, 2003 | 01:09 PM
zootzee's Avatar
Question Idiots guide to belt and spark plugs
I want to change the plugs wires and my belt can anyone send me or post the eaiest way of doing this.
I once read that you need a special tool to take the plugs out. If this is true where can I get one?
Also what kind of plugs, wires and belt do you guys suggest?
Any help would be great,
97 Tans Am Conver.
zootzee@hotmail.com
Old May 30, 2003 | 01:41 PM
TransAm219's Avatar
Belt is eazy , just get a 13mm socket and a breaker bar and pull counter clock wise on the tension pulley , the old belt will slip off and you may have to have a 2nd person route the new belt while you keep tension on the pulley
I dont know of any special tools for spark plug changes
Old May 30, 2003 | 04:34 PM
CW, not CCW on the tensioner pulley, as I recall.
Belt routing is shown on the radiator cover.
Old May 31, 2003 | 02:19 PM
zootzee's Avatar
Thanks, guys.
It sounds pretty, easy so I guess that I will give it a try.
Thanks again.
Old May 31, 2003 | 02:25 PM
Dave88LX's Avatar
Only special tool you need for sparkplugs is a small hand and skinny arms SOme are easier to get from the top, some easier from the bottom. The rear pass side is a PITA.
Pick yourself up a Chiltons or whatever for your car, has lots of tidbits of info that might help you with general questions.
Old May 31, 2003 | 02:26 PM
ibanez6rg's Avatar
I've see a customized socket that someone sells over eBay. I passed it up, didn't look that great
Old May 31, 2003 | 02:56 PM
ghostle's Avatar
Make sure to use anti-seize for alum. heads and don`t overtighten plugs, again because of alum. heads.
Old Jun 4, 2003 | 08:40 PM
zootzee's Avatar
That's it, no more advice?
Thanks guys.
Wish me luck, I have big hands.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
