Idiots guide to belt and spark plugs
I want to change the plugs wires and my belt can anyone send me or post the eaiest way of doing this.
I once read that you need a special tool to take the plugs out. If this is true where can I get one?
Also what kind of plugs, wires and belt do you guys suggest?
Any help would be great,
97 Tans Am Conver.
zootzee@hotmail.com
97 Tans Am Conver.
zootzee@hotmail.com
Belt is eazy , just get a 13mm socket and a breaker bar and pull counter clock wise on the tension pulley , the old belt will slip off and you may have to have a 2nd person route the new belt while you keep tension on the pulley
I dont know of any special tools for spark plug changes
Belt routing is shown on the radiator cover.
Only special tool you need for sparkplugs is a small hand and skinny arms
SOme are easier to get from the top, some easier from the bottom. The rear pass side is a PITA.
Pick yourself up a Chiltons or whatever for your car, has lots of tidbits of info that might help you with general questions.
SOme are easier to get from the top, some easier from the bottom. The rear pass side is a PITA. Pick yourself up a Chiltons or whatever for your car, has lots of tidbits of info that might help you with general questions.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
