identifying trick flow lt1 heads
Old Feb 12, 2005 | 07:53 PM
will62085's Avatar
i just bought a set of trick flow heads off a guy, new in box, but second hand heads...they look like lt1 heads, have center bolt valve covers holes, and angled spark plug holes, yet all the paperwork with the heads was for the 23 degree kenny dutweiler (sp??) heads...but nowhere on the heads does it say his name like its supposed to...im just making sure these are acutally lt1 heads...does trick flow make center bolt valve cover heads for non lt1 engines?
Old Feb 12, 2005 | 09:19 PM
zx1216's Avatar
Re: identifying trick flow lt1 heads
well there should be a number casted into the head so call up trick flow and ask them
Old Feb 12, 2005 | 09:29 PM
94zgreenmachine's Avatar
Trick flow does make heads for non lt1 small block chevys. They are the Kenny Duttweiler series and the r-series heads for small block chevy. They also make an 18 degree head.I would say to look at the intake ports on the heads. You should only have 4 opening for air)The lt1 heads have no coolant passages exposed that would flow thru the intake like traditional SBC
Old Feb 13, 2005 | 01:18 PM
will62085's Avatar
yeah there are no coolant ports on the intake side of the head...all the paper work is for the kenny dutwieler 23 degree heads...but these have to be lt1 heads...guess ill call trick flow monday and find out for sure
Old Feb 13, 2005 | 02:22 PM
squinn's Avatar
Trickflow lt1 heads look very much like gm lt1 heads. The difference I can see is that the pushrod area is open on a gm head and on a trickflow head they just drill a hole for the pushrod. Also the oil return holes are cast on the gm head and they are drilled on the Trickflow head. Hope this helps.
HectorM52
Jun 23, 2016 08:42 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
