Identifying cam.. was i Dooped?!
Old Sep 25, 2008 | 08:55 PM
dubbsix's Avatar
Bought a cam thats new, but noticed that the part number seems to be a custom grind..
Here are the details on the cam box:
07-000-08
LT 3314S / 3315s HR112+4
I thought this was a cc503 cam....
Old Sep 25, 2008 | 09:05 PM
Joe Urban's Avatar
What is etched/stamped on the end of the cam? Maybe someone just used a cam box they had lying around.
Joe Urban
Old Sep 25, 2008 | 09:20 PM
Green96Z's Avatar
Fourth post down:
http://web.camaross.com/forums/showthread.php?p=4452732
It sounds like you have the right cam. Just call Comp and ask them.
Old Sep 25, 2008 | 09:46 PM
87bandit's Avatar
my cc503 had the cam p/n etched on the end
Old Sep 25, 2008 | 10:12 PM
dubbsix's Avatar
My cam has the exact same numbers etched into the end of the cam...
Old Sep 25, 2008 | 10:24 PM
07-000-08
It is. If you look at the Comp Cams catalog and lobe chart, you will see that those lobes (3314 and 3315) are the 224/230 lobes. 112 is the LSA. All what the 503 has.
Old Sep 25, 2008 | 10:25 PM
zcardriver22's Avatar
That would be the lobe numbers etched on the cam. Look it up.
Old Sep 26, 2008 | 12:32 AM
dubbsix's Avatar
Thanks guys. This all started because i was trying to determine the correct push rods to run with this cam and a 1.6 Roller rocker
Old Sep 26, 2008 | 06:57 AM
Correct length pushrods are determined by measuring. It's not determined by cam and rockers. Stock length is 7.200".
Old Sep 26, 2008 | 11:07 AM
dubbsix's Avatar
Okay.. What changes in the valvetrain geometry require a change in push rod length?
Old Sep 26, 2008 | 11:58 AM
87bandit's Avatar
I run stock length with mine, not idea how correct it is though but runs good
Old Sep 26, 2008 | 12:11 PM
MeanGreen97Z's Avatar
Milled heads, gasket thickness, and deck height.
Old Sep 26, 2008 | 03:43 PM
SS RRR's Avatar
Rockers can influence PR length as well. If the rockers are changed the sweep must be checked.
Old Sep 26, 2008 | 09:59 PM
dubbsix's Avatar
Well the heads havent been shaved and the only other thing thats changed is the higher ratio rocker arm. I wont hunt for the perfect answer on this thread.. i'll just do my best to measure once everything comes together.
thanks guys.
cjamen
Jul 27, 2015 12:48 PM
Latronaxe
Jun 10, 2015 02:08 PM
taner
Advanced Tech
Nov 9, 2003 09:30 PM
PhantomTA
Sep 27, 2003 04:38 PM
Jeff H
Classic Engine Tech
Dec 1, 2002 02:35 PM
