Identifying a 4 bolt main LT1
Old Jul 31, 2011 | 07:39 AM
calaban's Avatar
Is there a way, aside from taking off the oil pan, to know if you have a 2 bolt or 4 bolt block?
Supposedly according to the paper work I got with my car, the engine was replaced at 65k. I do not know for sure as I'm the 4th or 5th owner and I got the car with 117k on the odometer.
I had also read that factory replacement engines normally had 4 bolts.
Is there a number on the block or anything that will identify this?
Old Jul 31, 2011 | 08:27 AM
RobsWS6's Avatar
Re: Identifying a 4 bolt main LT1
The crate engines were 4 bolt. Mine was replaced at 48K under warranty and it was a 4 bolt block.
I don't know if there is any identification marks on the block or not though.
Old Jul 31, 2011 | 10:52 AM
96capricemgr's Avatar
It is the same block, just additional machining, no external identifiers.
IMO factory 4-bolt is almost meaningless because by the time you need them you should be looking at aftermarket caps which means a new line bore anyway which is the expensive part. Only reason I can see worrying about it is so you know if you have to order new straight caps for existing 4-bolt or if you have a 2-bolt you ask your machine shop if they prefer splayed or straight.
HectorM52
Jul 30, 2017 11:46 AM
importkiller94
Parts Wanted
Jan 17, 2015 07:23 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
ddr698
Jan 9, 2015 10:05 AM
97 RedSS
Jun 10, 2003 07:58 PM
