Idea for reducing roller rocker noise...
My Comp Pro mags make the normal clackity clackity clack like they should for a fast lobe high lift cam, but I would like to reduce the noise if possible. They are not very loud, but just loud enough to be annoying.
My Chevy truck bed is Linex'd and the other day I threw a rock in the bed and it made a dampened sound unlike a rock being thrown into a truck bed with no Line-X. The Line-X coating is rubbery like and goes on a good 3/16" thick and appears to have some sound deadening capabilities.
I know the whole point of the LT4 composite valve covers was to reduce the roller rocker noise, maybe this coating will do it as well.
So I was thinking, has anyone ever heard of Line-X'ing the stock valve covers to reduce some of the noise from the roller rockers?
Update:
Line-X quoted me $40.00 to coat them. I am going to find some cheap cores and give it a shot. If anybody wants to sell some stock LT1 covers give me a shipped price to 40511.
Are you sure you have the O-lash and lifter preload adjustment correct? If the lifter preload is too loose, I could see where that would be a problem and cause noise. Personally, I haven't experienced any real degree of rocker noise with my set-up.
WD
WD
As mentioned, they shouldn't be that noisy---I don't know what adjustment is required with roller, but it is usually about 1/2 turn for most. You might try a little more while engine is running to see if they quiet down. Might try using a little heavier oil too, especiallyl if you are using a really light synthetic blend.
Masking excessively loud rockers by insulation may not be a good idea, if the cause is something other than ordinary rocker noise. JMHO
Once again, they really are not that loud. If the Line-X mod kills any of this noise then that is a plus.
I am confident they are adjusted correctly, I just want to do what is within reason to hush them up as much as possible. Right now I have them at 1/2 turn PZL.
Another reason they are louder is due to the rag top, you hear every single little sound unlike a hard top.
You may be treating the symptoms of the problem (noise) and not necessarily the root cause of the problem (not enough lifter pre-load).
Also, I could really use some of that Line-X in my new Colorado Z71 bed.
WD
WD
No difference in noise from 1/4 to 1/2 turns PZL. One more time guys, the noise I am hearing is normal roller lifter noise. I just want to do what I can to silence it beyond that.
oldschool
Feb 9, 2016 09:21 PM
