ICM grease?
Old Jul 30, 2007 | 02:39 PM
mrseven's Avatar
ICM grease?
Anyone know what kind of grease goes between the ICM and the heat sink it mounts to? Just ordered a brand new GM ICM cuz I think mine took a crap, car died in the middle of the road .
Old Jul 30, 2007 | 02:48 PM
sabre81's Avatar
You'll get a packet of grease with it. It is thermal grease. Not dielectric grease or anything else.
Old Jul 30, 2007 | 03:52 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
It should come with a package of grease. I installed a new OEM ICM a couple of months ago and the grease was supplied.
Old Jul 30, 2007 | 04:37 PM
dangalla's Avatar
i always use dielectric grease
Old Jul 30, 2007 | 04:43 PM
NVetro's Avatar
I used dielectric grease also, several times.
Old Jul 30, 2007 | 04:45 PM
Dave89IROC's Avatar
if you get no grease with it, go to a computer store and get heat transfer/CPU grease(old school Arctic Silver works great), you shouldn't use dielectric grease
Old Jul 30, 2007 | 04:48 PM
dangalla's Avatar
partial definition of dielectric grease
In addition to the things listed it is used for a heat conductor when some electronic components are mounted on surfaces to dissipate heat (like the ignition power stage on 700/900 models and 240's 89-93). It is non-conductive, but when you slide the connectors together there is metal-to-metal contact and the grease gets displaced but the area around connector is protected from moisture.
Old Jul 30, 2007 | 06:02 PM
mrseven's Avatar
I kinda figured the grease came with it, I just wanted to get some extra for the ICM on there now so my car doesn't die in the middle of nowhere. I'll see if I can find some thermal grease or something at Autozone.
Old Jul 30, 2007 | 06:06 PM
Romero155's Avatar
You can go to any computer store and buy a tube of thermalpaste which is used to go inbetween the CPU and heatsink on computers.
Old Jul 30, 2007 | 07:27 PM
The ICM is backed by a heat sink, so it makes sense that you would use heat sink grease.
Old Jul 30, 2007 | 08:08 PM
SS RRR's Avatar
Amen and amen.
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
tdigger9899
Sep 7, 2015 10:56 AM
