iat sensor question
Old Dec 21, 2004 | 06:52 PM
billy mensch's Avatar
iat sensor question
can the iat sensor on a 93 z28 make the car run lean i got a new fuel pump new pressure regulater and the car is still running lean manifolds turning a little red and surging down low
Old Dec 21, 2004 | 09:21 PM
GreenDemon's Avatar
Re: iat sensor question
You should be able to use a multimeter to check resistance of the IAT sensor by unplugging it and checking it cold and hot. Resistance should decrease with heat.
It might be possible but I would think it would be something more drastic, such as timing, for the manifolds to be glowing.
Old Dec 22, 2004 | 05:46 AM
slopokrodrigez's Avatar
A lean condition will not usually cause glowing manifolds. A rich condition can for sure. A lot of unburnt fuel may come out of the heads while it is still burning. BUT the number one reason for glowing manifolds on this board is a restricted exhaust. You should put the particulars of your car in your signature but since you didn't we will assume you have a cat and if so, it is probably plugged. If you can't check back pressure, try unhooking the exhaust before the cat and see if the glowing goes away. Should have a lot more power and pep too.
Dave
Old Dec 22, 2004 | 06:33 AM
IslandZ's Avatar
Lean causes glowing headers. You have to be rich almost to the point of hydrolocking to glow the headers.
Old Dec 24, 2004 | 08:55 AM
short run down started this every since hotcam spun rod bearing rebuilt motor still doing it no cat on it either fuel pump and pressure regulater all new
HectorM52
Jul 30, 2017 11:46 AM
grabbem88
Feb 13, 2015 03:09 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
