IAT Sensor "How To and Where To"
Old Aug 15, 2003 | 09:51 PM
mechmsb's Avatar
Ok guys I got my 94 Z28 back from the shop, it was sent there to get the hesitation fixed, and it got all new spark plugs, and throttle body was cleaned, I also told them to check the IAT sensor, and they did but there computer said it was working properly so they left that alone. Well I got it back, and when it gets hot it still hesitates from 1000-2000 rpms, I mean it literally bogs then goes then bogs then once you get out of that its full power. From the other posts I have came to believe even though the computer didn't pick up the IAT being bad, for $10 I still want to try it just incase computer didn't pick it up. Does anyone know of a good place to online to buy an IAT sensor. Also if you could give me directions on how to replace it, it would surely help.
Thanks Guys
Old Aug 15, 2003 | 10:13 PM
If you think you just have to replace it, it is one of the few things that can be replaced without tools.
Unplug electrical connector
Remove IAT-just pull it out
Insert new IAT
Replace electrical connector
Are you in the market for a 1LE intake elbow? It comes with a new IAT.
Old Aug 15, 2003 | 10:16 PM
Rodrigues's Avatar
When I did a cam install I removed all my emissions stuff when I did that and my hesitation went away.
Girrrrl
Aug 20, 2015 09:26 AM
Girrrrl
Aug 20, 2015 06:17 AM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
