IAC valve location // problem
Old Dec 4, 2011 | 01:43 PM
summers_Z28's Avatar
Does anyone know where the idle air control valve is located? --1994 camaro z28 -- 5.7l Lt1 --
I believe that's whats wrong with my car. Idle is little lower then it usually is, and when im stopped with the motor running the car will sometimes die unless i get on the throttle a little. Also while i am driving on the highway steady at 65 mph it will studder (typically only with cruise control on).
Old Dec 4, 2011 | 02:59 PM
Re: IAC valve location // problem
It's on the plate on the bottom of the throttle body. Shoebox has a photo:
http://shbox.com/1/iac3.jpg
.... and how to test it:
http://shbox.com/1/iac2.jpg
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
Jazsun
Dec 29, 2014 12:14 PM
