I want to thank everyone on this board
Old Feb 16, 2008 | 11:12 PM
95Blackhawk's Avatar
I have had some serious frustrations with my car. In just the last few hours, I figured it out and am moving forward with resolving the issue.
Great information was relayed to me that helped me tremendously. My problem was self-caused but with the help of many people, the problem surfaced and I solved it.
Thank you to everyone that supported me when I missed a key issue.
What was my issue?
I have mutiple old optisparks. So I thougth it would be OK to rebuild one of them since the bearing went out on one.
Please note, if you take apart the rotating components holding the bearing in place, you can NEVER get them back in the same position again. My timing was off and therefore was the cause of all my issues.
Issue noted and moving forward...
Old Feb 17, 2008 | 12:41 AM
sn8ke eatr's Avatar
this board has helped me a few times
Old Feb 17, 2008 | 10:03 AM
When you find the solution to a problem, its a good idea to go back to the various threads you used to describe the problem, and post the solution. It tells the people who tried to help you whether their suggestions worked, and it completes the story, so people who use the "search" function in the future will find not only the problem, but the solution.
Glad you worked it out.
bunker
Jan 30, 2016 08:09 PM
Daluchman1974
Sep 11, 2015 06:12 AM
TGGodfrey
Aug 17, 2015 08:43 PM
KYWes
Aug 10, 2015 07:03 PM
