I want to shoot my car!
Old Apr 27, 2008 | 01:08 PM
Slo93Z's Avatar
Just changed intake gasket.I let it set 4 about an hour before running When it got hot it started to leak coolent out of back of the motor up high. Not sure if its a head gasket or those hard lines that run from head 2 head ? I went 2 check the hard line by blowing air in 2 it and brock the fitting off the radiator. Can those hard lines on the back of the heads be deleted and pluged?
Old Apr 27, 2008 | 01:12 PM
caldercay's Avatar
Of course they can.
On the other hand, if you want the engine cooling system to do its job
properly, you will NOT want to delete and plug those.
First order of business to find find out where the coolant is leaking from.
Old Apr 27, 2008 | 03:26 PM
The_Bishop's Avatar
No, they can *not*. Those are needed for proper cooling of the cylinder heads.
Old Apr 27, 2008 | 05:06 PM
luckyou03's Avatar
I believe that hard line in the back of the heads is to purge air out of the rear of the heads.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
