I want a custom grind!
Old Aug 23, 2005 | 02:19 PM
  #16
SStrokerAce's Avatar
Re: I want a custom grind!
Originally Posted by Kurt Crosbie
I believe my quench is .037". Isn't that the distance between the top of the piston and the head?
Correct
I wouldn't go to the trouble of changing the pistons and what you have right now is good enough for the power levels you are looking at. You have ARP studs in the 2 bolt mains correct?
Bret
Old Aug 23, 2005 | 02:27 PM
  #17
Kurt Crosbie's Avatar
I hope they are ARP studs. Are you saying that I can make 525fwhp w/that compression and a 2-bolt main, and not have to worry about blowing the thing to smitherines?
I think 525fwhp is pushing around 470rwhp w/an M6 and 10-bolt. Thats laying down the law. Thats fast. I guess I will go ahead and port those heads out after all. I just did not know before that kind of hp was possible with lt1 castings.
Old Aug 23, 2005 | 02:46 PM
  #18
No I was saying that the bottom end can take that, who knows if it's going to make that much power.
FWIW I've done 600hp on a 383, LT1 castings ported by Lloyd and a Solid Roller with a single plane so it can be done with those castings just takes a little work.
Bret
Old Aug 23, 2005 | 02:58 PM
  #19
Z95m6's Avatar
I believe Phil at Ai had a post about one of their stock casting LT1 cars running low 10's and i also believe he said 500 NA rwhp is capable out of stock LT1 castings. I hope i remember that right. Double check by doing a search though.
Old Aug 23, 2005 | 05:16 PM
  #20
groundpoundinlt's Avatar
i got my custom grind from cam motion, who actually grinds allens cam at futral motorsports...hes a big LS1 guroo on the lsx boards....anyways the cam sounds amazing and has a good power band...you will need a list of all your mods, flow sheet of heads, etc etc and they will get you squared away...www.cammotion.com
Old Aug 23, 2005 | 07:16 PM
  #21
What is a single-plane intake?
Old Aug 23, 2005 | 07:36 PM
  #22
http://web.camaross.com/forums/showthread.php?t=388104
95chwagon
Oct 16, 2015 12:24 PM
kandied91z
Sep 30, 2015 11:43 PM
CARiD
Sep 30, 2015 05:44 AM
Bxlt1
Sep 29, 2015 03:18 PM
