i want 350-370 hp easiest way to achive this?
Old Nov 26, 2009 | 03:18 PM
1nicelt1's Avatar
i have a 94 z car is completly stock and i wanted to know the easiest way i can can get these numbers stated above have a 1500 dollar budget i was thinkin a port and cam and a few bolt-ons would do the trick. Also I was lookin at a 355 that has lt4 hot cam hand ported heads and new valve springs and he has it for a pretty good price but what do you guys think he also stated tha the engine has about 9000-10000 miles on it....
Old Nov 26, 2009 | 05:36 PM
Do you want 350-370 HP at the flywheel, or at the rear wheels? Makes a big difference.
If at the rear wheels, what trans do you have?
Old Nov 26, 2009 | 05:58 PM
The Untouchable's Avatar
it really depends on how much it was beat on, how well the heads were ported and a few other things , like do u plan on runnin LT's ?
Old Nov 26, 2009 | 06:17 PM
MikeGyver's Avatar
To answer your question, nitrous.
Old Nov 26, 2009 | 08:10 PM
bkpliskin's Avatar
you can reach that easily with bargain priced bolt ons if you're talking about flywheel hp
Old Nov 26, 2009 | 08:30 PM
7designs's Avatar
+1 if only when hitting button. But if want power all the time refills adds up.
Old Nov 27, 2009 | 04:06 PM
1nicelt1's Avatar
whats the difference between rear wheel and flywheel horse power? and i kinda wanted to stay away from nitrous.
Old Nov 27, 2009 | 04:09 PM
1nicelt1's Avatar
yeah i do want to run LTs
Old Nov 27, 2009 | 04:19 PM
RWHP is measured at the rear wheels on a chassis dyno. It takes into account driveline loss that flywheel HP (done on an engine dyno) does not. RWHP will be less than flywheel HP.
Old Nov 27, 2009 | 04:37 PM
1nicelt1's Avatar
then its most probably rearwheel where im trying to get those numbers then.
Old Nov 27, 2009 | 04:39 PM
1nicelt1's Avatar
i just want to break into like the 300+hp range but would really like to get those number i stated above...
Old Nov 27, 2009 | 08:20 PM
MikeGyver's Avatar
5 psi boost will add 100rwhp to a stock motor and get you there.
Cheap? No.
Increasing airflow over 40% on an already strong motor never is, get used to it lol.
Old Nov 27, 2009 | 09:05 PM
Then tell us whether the trans is is the A4 or the M6, so we can estimate drivetrain loss.
Your goals are over the place (300, 350, 370, probably rear wheel), and you haven't given us the info we need. Try to pin it down a little tighter.
Old Nov 27, 2009 | 09:55 PM
Klypto's Avatar
full bolt ons and cam should get you close
Old Nov 27, 2009 | 11:51 PM
reamo04's Avatar
long tubes, true duals, cold air intake, and a cam such as the cc503 will get you good drivability and close to 350 at the wheels probably.
