I was told an Eclipse MAF is the same as ours, is that true?
Old Jul 6, 2006 | 04:50 PM
Dave88LX's Avatar
If so, what years/generation? Trying to find a local MAF to borrow. I can get one brand new from O'Reilly's for $105.21, but if I need to know if it's the real problem or not first.
Anybody heard of this? (Yes I tried a search!)
While I'm on the subject...any other cars/engines with the same MAF?
Thanks...
Old Jul 6, 2006 | 05:53 PM
mattybz28's Avatar
Re: I was told an Eclipse MAF is the same as ours, is that true?
No.
Old Jul 6, 2006 | 05:54 PM
Cerwin Vega Fan's Avatar
Originally Posted by mattybz28
No.
indeed
Old Jul 6, 2006 | 07:10 PM
ze doktor's Avatar
not even close. eclipses are using F-Body MAFs with a MAF-Translator box to solve their own MAF problems (the mitsu MAFs are possibly the worst possible designed air flow sensor in existence).
Old Jul 6, 2006 | 07:17 PM
Dave88LX's Avatar
Thanks for the info! Appreciate it!
Old Jul 9, 2006 | 07:50 AM
Guest47904's Avatar
Guest
That's why there are test proceedures show you can check it without using parts.
Check yellow wire to black/white wire with key on for 5 volts. No less than 4 no higher than 6.
Check pink wire to black/white wire for 12 volts with key on.
Now with engine running check from yellow wire to ground with meter set to Frequency (Hz). Snap the throttle and be sure you get more than 7KHz response. If it is less try cleaning it. If it is still low, replace it.
Old Jul 9, 2006 | 01:28 PM
Dave88LX's Avatar
I checked it out in another thread here:
http://web.camaross.com/forums/showthread.php?t=459571
I have:
13.xxV across the black/white and pink.
6.3-7V between the yellow and black/white wire. Is that still OK? Or, do I have a problem somewhere else?
Old Jul 9, 2006 | 06:44 PM
Guest47904's Avatar
Guest
over 6 you have a problem.
What about the AC response?
checked mine out today. can't get more than 6KHz repsonse. It's got to go. Then probably the O2s cause running rich usually kills em.
Oh well, didn't need the extra money anyway. LOL
Old Jul 9, 2006 | 06:47 PM
Dave88LX's Avatar
Yeah I have over 6V KOEO, with the maf NOT connected to the wiring.
I don't have an o'scope to read that...I don't think I have anything that can, let me look.
Anon
Jul 23, 2015 12:18 PM
95blkss
Parts Wanted
Jul 19, 2015 08:42 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Noct
Jul 14, 2015 01:18 AM
