i was readin from the rear wheel 383 page and have a ?
Old Feb 14, 2003 | 01:08 PM
glennxx1's Avatar
guy said "As far as actual dyno #'s I have seen 390 or so with a Hot Cam, 6 speed and stock rearend, LT's, no cats, etc.
I have also seen 410 from an A4, 12 bolt, cc306, LT's , etc.
I have also seen 390 from a TH 400, 3500 stall, 12 bolt, cc306, LT's and a stock tune (ran out of $)." 390 horses with just removed cat, the hotcam, and he got 390 horses?
Old Feb 14, 2003 | 01:37 PM
red's Avatar
red
Each motor listed was a 383 stroker
Old Feb 14, 2003 | 02:18 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: i was readin from the rear wheel 383 page and have a ?
306 and lt4hc are hella different cams
Old Feb 14, 2003 | 02:37 PM
hsyr's Avatar
I'm not sure but maybe they forgot to mention the fully P&P heads on the motors too? 400RWHP from 33 extra cubs, CC306 and LTs/w stock heads doesn't seem very truthfull. Im sure they all have P&P heads.
Old Feb 14, 2003 | 04:26 PM
NightTrain66's Avatar
oops, my bad.
Yes, they all have ported heads with larger valves. I mentioned later in the thread that they had larger valves but I guess I left off the "ported" part.
The brief description are just general parts of their combination and notes about each. None had ever been dyno tuned and were still running on the "other" tune.
I listed trans type and cam size since the Cam has alot to do with RPM range and HP and the Trans (especially the guy with the TH400 and 3500 stall) type will also change the dyno #'s at the wheels.
NightTrain66
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
blac94Z
Nov 24, 2014 07:12 PM
squarehead
Nov 21, 2014 08:02 PM
