A.I.R pump operation
Old Nov 24, 2010 | 12:02 PM
wrd1972's Avatar
How long does the AIR pump run once the motor starts up?
Does it activate at every start up regardless of engine temp?
Old Nov 24, 2010 | 03:15 PM
RamAir95TA's Avatar
Re: A.I.R pump operation
The PCM turns on the AIR pump any time after startup when the coolant temperature is above 59-degrees (not before). It is turned off after 240 seconds or when the PCM enters closed loop.
It will not turn on if there is an SES light, RPM is greater than 2825 RPM, MAP is greater than 96kPa with VSS over 60mph, MAP is less than 20kPa, in PE mode, RPM is below 400, short and long term fuel trims are not in their normal ranges or ECT is less than 59-degrees.
Old Nov 24, 2010 | 08:51 PM
wrd1972's Avatar
Thanks. That covers it all right there.
ad356
Apr 11, 2015 11:12 PM
TrouserSnake
Aug 8, 2002 06:17 PM
TrouserSnake
Aug 7, 2002 12:43 PM
tbyrne
Jul 2, 2002 05:37 PM
