A.I.R. Manifold Plug
Old Jan 30, 2007 | 06:02 AM
ChevalierSS's Avatar
From searches, it looks like I'll need a 22mm drain plug to block off the AIR ports on the manifold. Apparently a 22mm plug only has a "sufficient" fit.
Is this hole in the manifold actually a pipe thread? Looks like it may be about a 1/2"-NPT?
I'm hoping it is, because, one, I'll get the best fit, and two, I can easily get a pipe plug from work.
Old Jan 30, 2007 | 07:48 AM
Chris 96 WS6's Avatar
No, an SAE plug won't fit, or at least didn't fit mine. I had to have the M22. Pipe plugs are tapered...the hole you're trying to plug isn't.
Old Jan 30, 2007 | 10:29 AM
fastchevy's Avatar
I used M22
Old Jan 30, 2007 | 02:29 PM
turnin20s's Avatar
On my brothers Impalla we took the pipe out of the manifold and welded the plug shut and put the stock piece back in. Works better than trying to find a plug that fits IMO
Old Jan 30, 2007 | 03:19 PM
TobyZ28's Avatar
I needed an M22. I also put a bunch of copper RTV around the threads to ensure no leaks.
Old Jan 30, 2007 | 03:43 PM
Mauiguyy911's Avatar
Anyone, what exactly is a M22 ?? as im going to be deleting my AIR also very soon as i just got some race version LT's..thanks
Old Jan 30, 2007 | 04:24 PM
G-BODYT56's Avatar
Cool
M22 is the reference to the METRIC threaded plug that is required to cap the A.I.R. hole in your manifold. You can find them at your local AUTOPARTS CHAINS, like Advance Auto, and so on. They are usually in their OIL DRAIN PLUG section. Less than $5.00 each. HTH's
Old Jan 30, 2007 | 05:24 PM
what i figured, thanks a lot, gonna have to pick one up
:edit: gonna have to pick two up,lol
Old Jan 31, 2007 | 05:27 AM
Mtrhds94Z's Avatar
Get 2.. there are 2 holes.. one on each header/manifold..
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
blkWidow
May 3, 2015 08:42 AM
rick350
Mar 14, 2015 10:46 PM
Jul 4, 2005 05:00 PM
