Spark Plugs
Old Jan 30, 2007 | 08:52 PM
Yenko97's Avatar
Spark Plugs
Im in the process of changing my spark plugs, I got 6, but i cant seem to get the 6th and 8th cylinders. I just cant get anything down the passenger side of the motor. Any help is appreciated, on getting these spark plugs removed.
Old Jan 30, 2007 | 09:00 PM
camarozz95's Avatar
I don't know how the hookers are on plug access but with my pacesetters I think i took a sparkplug socket slid it over the plug then got a box wrech to turn it and i could get to them that way
Old Jan 30, 2007 | 09:05 PM
Yenko97's Avatar
yea, its a strange design with the hooker's, I can hardly feel the plugs with my hand, much less fit a wrench down in there.
Old Jan 31, 2007 | 03:30 AM
2000GTP's Avatar
Try slipping the spark plug socket over the plug, then get a visual idea of what tool or tool combo you will need whether it be a stubby open end wrench or a small ratchet.
Old Jan 31, 2007 | 09:34 AM
OBE1 95Z28's Avatar
SLP sells a modified spark plug socket that's shorter. I had a friend at a machine shop modify a spark plug socket by making it shorter, cutting a U-shaped grove in the side to allow the top of the spark plug "pass through". I use a Gear Wrench on the hex end of the socket.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
