i need your advice on cams ((pleas check it out))
Old Dec 28, 2003 | 01:23 AM
SiDeWaYZz28's Avatar
Exclamation i need your advice on cams ((pleas check it out))
hey whats up everybody??well this is whats up i got enough money saved up for a powerdyne s/c 4.5 but the problem is ive been looking at alot of post saying its not good for the lt1. so i was thinking about doing jet hot lt with a cc306 and heads. . . what do you think i should do??and if i decide to do the cam . . .what will i need for the cc306??and where is the cheapest place to get one???o yea if theres anyother helpful advice on mods that i should do instead . . go ahead and let me know what would you do . . well thanks alot for checking out my post . . i really do appreciate the help!!!
Old Dec 28, 2003 | 01:44 AM
Super Mario's Avatar
Re: i need your advice on cams ((pleas check it out))
Powerdyne sucks. Their blowers don't spin worth a ****. You'd see more power gain out of cam, heads, & headers than you would 4.5 psi of boost, and your motor would last longer.
Old Dec 28, 2003 | 02:12 AM
Wild1's Avatar
Boost isn't worth it until you hit at least 10#s. Anyways, you live in Cali so if you don't need to worry about smog... then go for the 306 but remember to bump the compression...
Use an .029 Impala Head Gasket...
Or, use a .026 MR. Gasket for LT1s.
You'll need the increased compression to take care of the overlap.
Old Dec 28, 2003 | 02:51 AM
97WS6SCharged's Avatar
Or switch to an XE cam with less overlap. A 306 is supposed to be a N2O cam isn't it? Either way, it's old technology. You should look at the 230/236 or something similar.
Old Dec 28, 2003 | 03:23 AM
If you've got that much money, you could just purchase an LT4 conversion kit, some other shtuff to go along with it (tuning, etc)
Old Dec 28, 2003 | 03:39 AM
Why waste your money on the LT4 kit? You can make more power with a set of ported stock heads, stock LT1 intake, and a good cam.
Old Dec 28, 2003 | 11:22 AM
thanks alot guys for the info guys . . .should i go with the lt4 hotcam kit??will i notice a nice increase??im clueless about cams im new to the cam and heads . . but if you have a cam that you like please send me a link to where i can check it out . . .thanks again everybody .. im doing a search trying to learn some stuff on cams . . o yea im not worried about smog . . so let me know what setup you would go with or have . . . thanks again
Old Dec 28, 2003 | 11:34 AM
NegativeCreep's Avatar
Try contacting one of the sites vendors like http://www.cmotorsports.com/
They can help you put togather a good heads&cam package.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
