i need some help removing my center console
Old Jan 14, 2004 | 01:49 AM
pimpinphil's Avatar
my girlfriend was driving my car the other day,and we pulled in front of her mom's house,and she pulled up the e-brake,after we stopped,and something messed up,now,it wont come up,its in the down position,and try to pull it up,it is very tight,anyone have any problem with this?maybe a recall,or what else could it be?i tried to take the console out,but it looks like i need to have the e brake up,to get it fully off,is this true?or there some way i can un screw the e-brake handle or something,i cant get it up far enough to see whats wrong under there,any help is greatly appreciated,thanks alot.
phil
p.s. it is the 97 z in my sig thanks again.
Old Jan 14, 2004 | 02:08 AM
InjectedSS's Avatar
Re: i need some help removing my center console
phil
I think I solved your problem with the first 9 words in your sentence my girlfriend was driving my car the other day
Yea you do have to have the e-brake up to get the console off.. Look in the little rubber molding around the e-brake and make sure nothing is wedging it...
Old Jan 14, 2004 | 08:14 AM
bad1LEz's Avatar
On mine (94) look for a little screw that holds the handle and button on. Unscrew this and both will come off, leaving you with just the steel ebrake lever. Make sure you keep the spring that comes off. Loosen the entire console, and have someone hold up as hard as they can on the lever. Mine was really tight, and I swore alot, but I could finally slide the console up over the lever.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
F'n1996Z28SS
Jun 3, 2015 09:39 AM
eanhl2004
Apr 4, 2015 12:01 PM
mattstrike
Mar 11, 2015 07:33 PM
CaRParts102
Dec 6, 2014 08:45 AM
