I need to put the bird on a diet, need advice!!
Old Jul 2, 2004 | 01:31 PM
97firechicken's Avatar
i need to shed some pounds, ok actually alot of pounds, any ideas?
Old Jul 2, 2004 | 01:43 PM
BUBBA's Avatar
How tall are you and how much do you weigh?
Fast94T/A's Avatar
Rear seats, gas tank sheet metal. front sway bar. All rear carpet.
Anmy thing really spare tire.
Brake
Old Jul 2, 2004 | 01:44 PM
any extra weight, i got the seats gone, i do need to get out the carpet.
Old Jul 2, 2004 | 01:58 PM
Dave88LX's Avatar
Any extra nuts/bolts/screws that aren't doing anything
Wheels: My Centerline Warriors for my Mustang are EXTREMELY light.
Old Jul 2, 2004 | 02:23 PM
Red96Lt1's Avatar
Passenger seat, head liner, clean the under cariage of dirt and mud. K member. Go on a diet
Old Jul 2, 2004 | 02:24 PM
no doubt, yeah i want to do the K member one day but i dont know how bad that is of an install. i need to get some racing seats.
Old Jul 2, 2004 | 03:29 PM
Steve in Seattle's Avatar
ditch the rear seats, spare tire, jack, trunk lining, carpeting (if you're brave enough... I'm not), floor mats (personally I keep the driver's in), passenger seat if your a the track.
get some light rims (like real ZR1's or a pricy aftermarket design), ditch the front sway bar, ditch the center consol (or at least all the contents), remove the front sway bar at the track, empty the windshield washer fluid, transplant the battery to the spare tire well and go with a small drag battery at the track. Remove the AC controls, wiring, pump, heatercore, and vents. REmove the passenger and driverside air bag, STB.
That's about all the easy stuff I can think of (AC isn't that easy mechanically, but it has little impact other than rolling down the windows).
Oh yeah, bumper crash foam and teh impact plastic down there as well. For more exotic weight-loss, remove the pop-up lamps and they're support brackets/motor/sensor, then fab a clear-acrylic cover to permant mount some lights up front. Ditching the fog lamps and using tubing to make the 2 TA holes up front pass-through vents (which can be tapped for brake ducts if you road race) would also save some weight and air-resistance.
Good luck.
Old Jul 2, 2004 | 03:35 PM
iNF3RNo's Avatar
Drill as many 1/4 inch holes in frame rails as you feel comfortable with.
Could even extend that practice to your wheels.
And yes, I'm kidding.
Old Jul 2, 2004 | 03:51 PM
hahaha that was good, you got me at first.
thanks guys, not i get to tear apart my car.
Jun 6, 2015 08:27 AM
jj_burchiel
Mar 21, 2015 12:51 AM
edxiel
Jan 24, 2015 07:40 PM
David Dorris
Jan 17, 2015 08:10 PM
1775.Z28
Jan 11, 2015 10:51 AM
