I need plugs for A.I.R. fittings in headers
Originally posted by anaik
I think the reason the M22's and M18's can be used in there place is because of corrosion in the threads.
Originally posted by nateh
I have RKSport/ASM Headers and the AIR tubes take an M22X1.5 plug. Anyone want to volunteer their AIR tube plug size and what headers they fit?
7/8" = .875"
22 mm. = .866"
7/8 X (18) = obviously 18 tpi
22 X (1.5) = 17 tpi
As stated above the metric plug is small enuf (sloppy) to allow the 1 tpi interference to actually screw in for a certain depth.
There are (were) several on another forum who were quite sure the thread (oem) was metric. It took a near act of the Almighty to convince them otherwise. My craft (trade) requires that I be familiar with threads and thread pitches. I also stand on what I stated previously, ain't such a thing (AFAIK) as a metric inverted flair thread. OEM is NOT metric! Why does the aftermarket install the holes in the first place? Aftermarket does not have their own AIR kits, so the answer is to fit OEM plumbing.
I don't get it then.
edit: I guess it really doesn't matter, as long as the opening at the entrance to the fitting is sealed.
Granted, others have installed metric and gotten away with it. To each his/her own.
Rather than by the correct pitch plugs, I just weld a plug into a short section of the oem tube, which uses the oem fitting nut to do the sealing.
Edit: I take that back. I didn't weld anything. I used a machined plug, with the correct amount of pr. fit, and just pressed them in. How soon I forget some things.
As to fit, I was able to screw a metric plug all the way down until it bottomed. No interference at all and a nice easy turn with my fingers.
Hear, hear, I've been redeemed.
As for different years having different sizes of fittings, check the part #s for the different year exhaust manifolds, I know for a fact, one particular model uses both the 7/8 and 3/4 size fittings, depending on the year, yet take the same manifold part #, and I have verified oem installed as also being the same part. The diff being a particular year (later) plumbing being smaller, which required a reducing bushing in the manifold. FFT
I have the manifold plugs
I have 4 plugs available that I had made, they are 17-4 stainless
7/8 threads, with a hex head, they bottom out in the tapped hole and require no sealant. Email me.
I chased this problem for about two months and this fixed it.
Jul 4, 2005 05:00 PM
