I need a new in tank fuel pump.....
Old Oct 31, 2004 | 01:23 AM
AZ94FORMULA's Avatar
I need a in tank fuel pump that can support up to 500 HP
What should I buy and where can I buy it?!?!?!
Thanks in advance!
Old Oct 31, 2004 | 07:50 AM
sssalah's Avatar
Re: I need a new in tank fuel pump.....
Walbro 255l high pressure pump (I think the pn is GS340) should get you there.
Old Oct 31, 2004 | 07:57 AM
Derrick Redd's Avatar
Thumbs up Re: I need a new in tank fuel pump.....
Ditto. Walbro 255lph intank should fit the bill.
Old Oct 31, 2004 | 08:31 AM
Z95m6's Avatar
I would get the Racetronix setup.
Old Oct 31, 2004 | 11:47 AM
flyinZ's Avatar
Ya, they're plug-n-play setup would set you up pretty nice...Its a little more pricey, but it saves you the hassle in the long run..
Old Oct 31, 2004 | 12:08 PM
ChevyTuffD.A.'s Avatar
Is the Walbro pump not a direct plug in set-up or what??
Old Oct 31, 2004 | 12:25 PM
TCAL95Z's Avatar
Hi Kurt.
Get the Racetronix kit. I put mine in and I just fixed my gas gauge with a new sending unit.
Old Oct 31, 2004 | 12:51 PM
CamaroBoy96Z28's Avatar
No its not. The bucket in the tank causes trouble with just throwing in a pump. That's why the Racetronix kit is such a good way to go and why so many swear by it. I believe with LT1 F-bodies that its important putting your money in the right places and this is one of those places. Save hassle and aggrevation all for cheaper than a replacement stock pump and go Racetronix.
Old Oct 31, 2004 | 12:57 PM
Where is a good place to look for one of those Racetronix kits??
Old Oct 31, 2004 | 01:04 PM
tonylittell's Avatar
www.racetronix.com
Old Oct 31, 2004 | 01:14 PM
SO am i going to need the fuel pump assembly and that plug and play system?? Or just the fuel pump assembly itself?
Old Oct 31, 2004 | 03:37 PM
Z95m6's Avatar
Get the harness too. Adding the harness alone to my car jumped my volts on the charging degree 1 whole volt. If you read on racetronix site it says increasing the voltage increases the fuel output.
Old Oct 31, 2004 | 03:43 PM
95 Z/28 LT1's Avatar
Super Moderator
Another vote for the Racetronix kit. Get the harness and the pump kit.
Old Oct 31, 2004 | 05:32 PM
Racetronix's Avatar
Depends on your req'd HP support.
Old Oct 31, 2004 | 05:58 PM
Full bolt-ons and cam and eventually a 125 shot of N20. I am not sure how much that is but I am going to say with nitrous its going to be around 500fwhp.
