I need a little cam help
I have done some searching but I haven't quite found what I am looking for. I am planning to install a cam in my 96 WS6 soon and I am can't decide which one to go with. My car is a weekend car, non subject to emissions testing and is in the process of becoming a full bolt on car. I want a cam that will work with my stock heads for now and then compliment a set of heads later. My car does have a 2800 stall also. I plan to stay with the 3.23 gears. Which cam will give me the most bang for my investment. Thanks
Steve
Steve
Re: I need a little cam help
best value would be the GM LT4 Hot cam. $500= and includes everything you need. However if you go full bolt ons later and upgrade the heads, the LT4 hot cam will still work good, but at that point a larger cam wouldn't hurt either.
